Time Before: 0.01886 seconds
Time After: 0.02262 seconds
Time Taken: 0.00375 seconds
Time Before: 0.02272 seconds
Time After: 0.02318 seconds
Time Before: 0.02341 seconds
Time After: 0.02357 seconds
Time Before: 0.02427 seconds
Time After: 0.02680 seconds
Time Taken: 0.00253 seconds
Time Before: 0.02362 seconds
Time After: 0.03070 seconds
Time Taken: 0.00708 seconds
Time Before: 0.03494 seconds
Time After: 0.03534 seconds
Time Before: 0.03673 seconds
Time After: 0.03794 seconds
Time Before: 0.03429 seconds
Time After: 0.03814 seconds
Time Taken: 0.00386 seconds
Time Before: 0.06893 seconds
Time After: 0.06907 seconds
Time Before: 0.08068 seconds
Time After: 0.08192 seconds
Time Before: 0.09103 seconds
Time After: 0.09120 seconds
Time Before: 0.09345 seconds
Time After: 0.09488 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=116420' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.11352 seconds
Time After: 0.11378 seconds
