Time Before: 0.01694 seconds
Time After: 0.02052 seconds
Time Taken: 0.00358 seconds
Time Before: 0.02061 seconds
Time After: 0.02100 seconds
Time Before: 0.02121 seconds
Time After: 0.02138 seconds
Time Before: 0.02226 seconds
Time After: 0.02449 seconds
Time Taken: 0.00224 seconds
Time Before: 0.02143 seconds
Time After: 0.02819 seconds
Time Taken: 0.00676 seconds
Time Before: 0.03290 seconds
Time After: 0.03333 seconds
Time Before: 0.03589 seconds
Time After: 0.03707 seconds
Time Taken: 0.00118 seconds
Time Before: 0.03216 seconds
Time After: 0.03727 seconds
Time Taken: 0.00511 seconds
Time Before: 0.07198 seconds
Time After: 0.07213 seconds
Time Before: 0.08592 seconds
Time After: 0.08717 seconds
End call of global.php: 0.089241981506348
Time Before: 0.09440 seconds
Time After: 0.09462 seconds
Time Before: 0.09698 seconds
Time After: 0.09842 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=116483'
Time Before: 0.11704 seconds
Time After: 0.11745 seconds
Memory Before: 4,288.695 KB
Memory After: 4,288.938 KB
Page generated in 0.11597800254822 seconds with 9 queries, spending 0.0078599452972412 doing MySQL queries and 0.10811805725098 doing PHP things.
