Time Before: 0.01768 seconds
Time After: 0.03067 seconds
Time Taken: 0.01299 seconds
Time Before: 0.03075 seconds
Time After: 0.03113 seconds
Time Before: 0.03132 seconds
Time After: 0.03147 seconds
Time Before: 0.03230 seconds
Time After: 0.03490 seconds
Time Taken: 0.00259 seconds
Time Before: 0.03154 seconds
Time After: 0.03960 seconds
Time Taken: 0.00806 seconds
Time Before: 0.05092 seconds
Time After: 0.05130 seconds
Time Before: 0.05278 seconds
Time After: 0.05397 seconds
Time Before: 0.05025 seconds
Time After: 0.05422 seconds
Time Taken: 0.00397 seconds
Time Before: 0.08814 seconds
Time After: 0.08831 seconds
Time Before: 0.11494 seconds
Time After: 0.11716 seconds
Time Taken: 0.00223 seconds
End call of global.php: 0.11977601051331
Time Before: 0.13462 seconds
Time After: 0.13484 seconds
Time Before: 0.13738 seconds
Time After: 0.13882 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=116488', badlocation = 1
Time Before: 0.15879 seconds
Time After: 0.15918 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.1574170589447 seconds with 9 queries, spending 0.0091404914855957 doing MySQL queries and 0.14827656745911 doing PHP things.
