Time Before: 0.01209 seconds
Time After: 0.01701 seconds
Time Taken: 0.00491 seconds
Time Before: 0.01711 seconds
Time After: 0.01754 seconds
Time Before: 0.01782 seconds
Time After: 0.01795 seconds
Time Before: 0.01880 seconds
Time After: 0.02095 seconds
Time Taken: 0.00216 seconds
Time Before: 0.01803 seconds
Time After: 0.02533 seconds
Time Taken: 0.00730 seconds
Time Before: 0.02948 seconds
Time After: 0.02990 seconds
Time Before: 0.03286 seconds
Time After: 0.03404 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02883 seconds
Time After: 0.03423 seconds
Time Taken: 0.00540 seconds
Time Before: 0.05768 seconds
Time After: 0.05782 seconds
Time Before: 0.06715 seconds
Time After: 0.06838 seconds
End call of global.php: 0.070760011672974
Time Before: 0.07407 seconds
Time After: 0.07425 seconds
Time Before: 0.07707 seconds
Time After: 0.07851 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=116504'
Time Before: 0.09548 seconds
Time After: 0.09580 seconds
Page generated in 0.094456911087036 seconds with 9 queries, spending 0.0076167583465576 doing MySQL queries and 0.086840152740479 doing PHP things.
