Time Before: 0.00675 seconds
Time After: 0.00829 seconds
Time Taken: 0.00154 seconds
Time Before: 0.00837 seconds
Time After: 0.00896 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00924 seconds
Time After: 0.00938 seconds
Time Before: 0.01023 seconds
Time After: 0.01270 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00946 seconds
Time After: 0.01698 seconds
Time Taken: 0.00752 seconds
Time Before: 0.02026 seconds
Time After: 0.02072 seconds
Time Before: 0.02339 seconds
Time After: 0.02473 seconds
Time Taken: 0.00134 seconds
Time Before: 0.01957 seconds
Time After: 0.02497 seconds
Time Taken: 0.00540 seconds
Time Before: 0.03947 seconds
Time After: 0.03964 seconds
Time Before: 0.04791 seconds
Time After: 0.04915 seconds
Time Before: 0.05557 seconds
Time After: 0.05580 seconds
Time Before: 0.05867 seconds
Time After: 0.06016 seconds
UPDATE session SET lastactivity = 1784791819, location = '/forums/private.php?do=newpm&explain=1&u=116517' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.08122 seconds
Time After: 0.08155 seconds
Memory Before: 4,289.063 KB
Memory After: 4,289.289 KB
