Time Before: 0.02357 seconds
Time After: 0.02927 seconds
Time Taken: 0.00570 seconds
Time Before: 0.02937 seconds
Time After: 0.02972 seconds
Time Before: 0.02994 seconds
Time After: 0.03006 seconds
Time Before: 0.03077 seconds
Time After: 0.03287 seconds
Time Taken: 0.00210 seconds
Time Before: 0.03012 seconds
Time After: 0.03828 seconds
Time Taken: 0.00816 seconds
Time Before: 0.04472 seconds
Time After: 0.04517 seconds
Time Before: 0.04821 seconds
Time After: 0.04945 seconds
Time Before: 0.04389 seconds
Time After: 0.04965 seconds
Time Taken: 0.00576 seconds
Time Before: 0.09449 seconds
Time After: 0.09465 seconds
Time Before: 0.11315 seconds
Time After: 0.11439 seconds
End call of global.php: 0.11673188209534
Time Before: 0.12334 seconds
Time After: 0.12350 seconds
Time Before: 0.12603 seconds
Time After: 0.12755 seconds
Time Taken: 0.00152 seconds
SET lastactivity = 1776606622, location = '/forums/private.php?do=newpm&explain=1&u=116578'
Time Before: 0.15382 seconds
Time After: 0.15420 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.15254497528076 seconds with 9 queries, spending 0.007697582244873 doing MySQL queries and 0.14484739303589 doing PHP things.
