Time Before: 0.00165 seconds
Time After: 0.00216 seconds
Time Before: 0.00223 seconds
Time After: 0.00296 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00323 seconds
Time After: 0.00336 seconds
Time Before: 0.00436 seconds
Time After: 0.00717 seconds
Time Taken: 0.00281 seconds
Time Before: 0.00341 seconds
Time After: 0.01056 seconds
Time Taken: 0.00715 seconds
Time Before: 0.01237 seconds
Time After: 0.01288 seconds
Time Before: 0.01536 seconds
Time After: 0.01663 seconds
Time Before: 0.01171 seconds
Time After: 0.01680 seconds
Time Taken: 0.00509 seconds
Time Before: 0.02174 seconds
Time After: 0.02194 seconds
Time Before: 0.02384 seconds
Time After: 0.02508 seconds
Time Before: 0.02789 seconds
Time After: 0.02808 seconds
Time Before: 0.03005 seconds
Time After: 0.03157 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1789019341, location = '/forums/private.php?do=newpm&explain=1&u=116586' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04374 seconds
Time After: 0.04447 seconds
