Time Before: 0.02192 seconds
Time After: 0.02828 seconds
Time Taken: 0.00636 seconds
Time Before: 0.02838 seconds
Time After: 0.02881 seconds
Time Before: 0.02902 seconds
Time After: 0.02913 seconds
Time Before: 0.02991 seconds
Time After: 0.03197 seconds
Time Taken: 0.00205 seconds
Time Before: 0.02919 seconds
Time After: 0.03650 seconds
Time Taken: 0.00731 seconds
Time Before: 0.04440 seconds
Time After: 0.04480 seconds
Time Before: 0.04630 seconds
Time After: 0.04754 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04365 seconds
Time After: 0.04779 seconds
Time Taken: 0.00414 seconds
Memory After: 2,261.820 KB
Time Before: 0.06952 seconds
Time After: 0.06966 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.08817 seconds
Time After: 0.08942 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.091728925704956
Time Before: 0.10199 seconds
Time After: 0.10265 seconds
Time Taken: 0.00065 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.10544 seconds
Time After: 0.10690 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788946493, location = '/forums/private.php?do=newpm&explain=1&u=116600', badlocation = 1
Time Before: 0.12607 seconds
Time After: 0.12629 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.12509393692017 seconds with 9 queries, spending 0.0079598426818848 doing MySQL queries and 0.11713409423828 doing PHP things.
