Time Before: 0.00151 seconds
Time After: 0.00204 seconds
Time Before: 0.00211 seconds
Time After: 0.00256 seconds
Time Before: 0.00284 seconds
Time After: 0.00296 seconds
Time Before: 0.00385 seconds
Time After: 0.00634 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00301 seconds
Time After: 0.00982 seconds
Time Taken: 0.00681 seconds
Time Before: 0.01174 seconds
Time After: 0.01220 seconds
Time Before: 0.01494 seconds
Time After: 0.01609 seconds
Time Taken: 0.00115 seconds
Time Before: 0.01111 seconds
Time After: 0.01626 seconds
Time Taken: 0.00515 seconds
Time Before: 0.02128 seconds
Time After: 0.02150 seconds
Time Before: 0.02385 seconds
Time After: 0.02509 seconds
Time Before: 0.02925 seconds
Time After: 0.02939 seconds
Time Before: 0.03249 seconds
Time After: 0.03392 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=116626' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04639 seconds
Time After: 0.04692 seconds
Time Taken: 0.00054 seconds
