Time Before: 0.00149 seconds
Time After: 0.00196 seconds
Time Before: 0.00204 seconds
Time After: 0.00241 seconds
Time Before: 0.00263 seconds
Time After: 0.00278 seconds
Time Before: 0.00344 seconds
Time After: 0.00567 seconds
Time Taken: 0.00223 seconds
Time Before: 0.00283 seconds
Time After: 0.00907 seconds
Time Taken: 0.00624 seconds
Time Before: 0.01079 seconds
Time After: 0.01100 seconds
Time Before: 0.01334 seconds
Time After: 0.01462 seconds
Time Before: 0.01024 seconds
Time After: 0.01480 seconds
Time Taken: 0.00456 seconds
Time Before: 0.02034 seconds
Time After: 0.02055 seconds
Time Before: 0.02233 seconds
Time After: 0.02373 seconds
Time Taken: 0.00140 seconds
Time Before: 0.02852 seconds
Time After: 0.02873 seconds
Time Before: 0.03153 seconds
Time After: 0.03303 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1783178700, location = '/forums/private.php?do=newpm&explain=1&u=116634', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.04971 seconds
Time After: 0.05049 seconds
Time Taken: 0.00078 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
