Time Before: 0.00162 seconds
Time After: 0.00208 seconds
Time Before: 0.00215 seconds
Time After: 0.00251 seconds
Time Before: 0.00270 seconds
Time After: 0.00280 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00350 seconds
Time After: 0.00577 seconds
Time Taken: 0.00227 seconds
Time Before: 0.00285 seconds
Time After: 0.00939 seconds
Time Taken: 0.00654 seconds
Time Before: 0.01125 seconds
Time After: 0.01161 seconds
Time Before: 0.01440 seconds
Time After: 0.01561 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01069 seconds
Time After: 0.01581 seconds
Time Taken: 0.00512 seconds
Memory After: 2,261.703 KB
Time Before: 0.02148 seconds
Time After: 0.02162 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02342 seconds
Time After: 0.02471 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.026376962661743
Time Before: 0.02772 seconds
Time After: 0.02787 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03007 seconds
Time After: 0.03154 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=116640'
Time Before: 0.04493 seconds
Time After: 0.04529 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.043993949890137 seconds with 9 queries, spending 0.0077030658721924 doing MySQL queries and 0.036290884017944 doing PHP things.
