Time Before: 0.04639 seconds
Time After: 0.05278 seconds
Time Taken: 0.00639 seconds
Time Before: 0.05290 seconds
Time After: 0.05334 seconds
Time Before: 0.05360 seconds
Time After: 0.05380 seconds
Time Before: 0.05452 seconds
Time After: 0.05675 seconds
Time Taken: 0.00223 seconds
Time Before: 0.05387 seconds
Time After: 0.06122 seconds
Time Taken: 0.00735 seconds
Time Before: 0.07096 seconds
Time After: 0.07336 seconds
Time Taken: 0.00240 seconds
Time Before: 0.07585 seconds
Time After: 0.07744 seconds
Time Taken: 0.00159 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.07024 seconds
Time After: 0.07771 seconds
Time Taken: 0.00747 seconds
Memory After: 2,261.820 KB
Time Before: 0.13455 seconds
Time After: 0.13482 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.15840 seconds
Time After: 0.16042 seconds
Time Taken: 0.00202 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.17558 seconds
Time After: 0.17578 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.17872 seconds
Time After: 0.18316 seconds
Time Taken: 0.00444 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789089791, location = '/forums/private.php?do=newpm&explain=1&u=116690', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.20755 seconds
Time After: 0.20782 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
