Time Before: 0.01191 seconds
Time After: 0.01460 seconds
Time Taken: 0.00269 seconds
Time Before: 0.01470 seconds
Time After: 0.01523 seconds
Time Taken: 0.00054 seconds
Time Before: 0.01552 seconds
Time After: 0.01566 seconds
Time Before: 0.01649 seconds
Time After: 0.01925 seconds
Time Taken: 0.00276 seconds
Time Before: 0.01574 seconds
Time After: 0.02470 seconds
Time Taken: 0.00896 seconds
Time Before: 0.03077 seconds
Time After: 0.03121 seconds
Time Before: 0.03421 seconds
Time After: 0.03543 seconds
Time Before: 0.03007 seconds
Time After: 0.03568 seconds
Time Taken: 0.00560 seconds
Time Before: 0.06022 seconds
Time After: 0.06041 seconds
Time Before: 0.07153 seconds
Time After: 0.07281 seconds
End call of global.php: 0.075289011001587
Time Before: 0.08145 seconds
Time After: 0.08162 seconds
Time Before: 0.08412 seconds
Time After: 0.08560 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=116719'
Time Before: 0.10727 seconds
Time After: 0.10755 seconds
Memory Before: 4,288.695 KB
Memory After: 4,288.938 KB
Page generated in 0.10627388954163 seconds with 9 queries, spending 0.0084998607635498 doing MySQL queries and 0.097774028778076 doing PHP things.
