Time Before: 0.01487 seconds
Time After: 0.02016 seconds
Time Taken: 0.00529 seconds
Time Before: 0.02029 seconds
Time After: 0.02086 seconds
Time Taken: 0.00057 seconds
Time Before: 0.02119 seconds
Time After: 0.02136 seconds
Time Before: 0.02216 seconds
Time After: 0.02514 seconds
Time Taken: 0.00297 seconds
Time Before: 0.02144 seconds
Time After: 0.02886 seconds
Time Taken: 0.00742 seconds
Time Before: 0.03604 seconds
Time After: 0.03676 seconds
Time Taken: 0.00073 seconds
Time Before: 0.03926 seconds
Time After: 0.04049 seconds
Time Before: 0.03518 seconds
Time After: 0.04072 seconds
Time Taken: 0.00555 seconds
Time Before: 0.06173 seconds
Time After: 0.06190 seconds
Time Before: 0.29165 seconds
Time After: 0.29348 seconds
Time Taken: 0.00183 seconds
Time Before: 0.30018 seconds
Time After: 0.30039 seconds
Time Before: 0.30290 seconds
Time After: 0.30462 seconds
Time Taken: 0.00172 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=116742', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.32134 seconds
Time After: 0.32165 seconds
