Time Before: 0.00218 seconds
Time After: 0.00279 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00290 seconds
Time After: 0.00332 seconds
Time Before: 0.00358 seconds
Time After: 0.00372 seconds
Time Before: 0.00460 seconds
Time After: 0.00716 seconds
Time Taken: 0.00256 seconds
Time Before: 0.00378 seconds
Time After: 0.01112 seconds
Time Taken: 0.00734 seconds
Time Before: 0.01342 seconds
Time After: 0.01398 seconds
Time Taken: 0.00056 seconds
Time Before: 0.01648 seconds
Time After: 0.01770 seconds
Time Before: 0.01251 seconds
Time After: 0.01797 seconds
Time Taken: 0.00547 seconds
Time Before: 0.02482 seconds
Time After: 0.02495 seconds
Time Before: 0.02690 seconds
Time After: 0.02812 seconds
Time Before: 0.03167 seconds
Time After: 0.03182 seconds
Time Before: 0.03468 seconds
Time After: 0.03639 seconds
Time Taken: 0.00171 seconds
UPDATE session SET lastactivity = 1788984822, location = '/forums/private.php?do=newpm&explain=1&u=116743', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.05358 seconds
Time After: 0.05447 seconds
Time Taken: 0.00089 seconds
