Time Before: 0.02762 seconds
Time After: 0.03583 seconds
Time Taken: 0.00820 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.03594 seconds
Time After: 0.03641 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03666 seconds
Time After: 0.03683 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03770 seconds
Time After: 0.04050 seconds
Time Taken: 0.00280 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03691 seconds
Time After: 0.04419 seconds
Time Taken: 0.00728 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.05494 seconds
Time After: 0.05536 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.05813 seconds
Time After: 0.05940 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.05415 seconds
Time After: 0.05960 seconds
Time Taken: 0.00546 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.10242 seconds
Time After: 0.10260 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.15693 seconds
Time After: 0.15862 seconds
Time Taken: 0.00168 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
End call of global.php: 0.16076803207397
Time Before: 0.18628 seconds
Time After: 0.18647 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.19189 seconds
Time After: 0.19336 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=116761', badlocation = 1
Time Before: 0.21821 seconds
Time After: 0.21846 seconds
Memory Before: 5,997.836 KB
Memory After: 5,998.055 KB
Page generated in 0.21716904640198 seconds with 9 queries, spending 0.0089168548583984 doing MySQL queries and 0.20825219154358 doing PHP things.
