Time Before: 0.00133 seconds
Time After: 0.00194 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00200 seconds
Time After: 0.00243 seconds
Time Before: 0.00266 seconds
Time After: 0.00289 seconds
Time Before: 0.00357 seconds
Time After: 0.00595 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00294 seconds
Time After: 0.00946 seconds
Time Taken: 0.00653 seconds
Time Before: 0.01141 seconds
Time After: 0.01175 seconds
Time Before: 0.01429 seconds
Time After: 0.01551 seconds
Time Before: 0.01070 seconds
Time After: 0.01571 seconds
Time Taken: 0.00501 seconds
Time Before: 0.02089 seconds
Time After: 0.02102 seconds
Time Before: 0.02316 seconds
Time After: 0.02440 seconds
End call of global.php: 0.026129961013794
Time Before: 0.02744 seconds
Time After: 0.02769 seconds
Time Before: 0.03003 seconds
Time After: 0.03164 seconds
Time Taken: 0.00161 seconds
SET lastactivity = 1784817669, location = '/forums/private.php?do=newpm&explain=1&u=116767'
Time Before: 0.04421 seconds
Time After: 0.04459 seconds
Page generated in 0.043292999267578 seconds with 9 queries, spending 0.0082008838653564 doing MySQL queries and 0.035092115402222 doing PHP things.
