Time Before: 0.01820 seconds
Time After: 0.02374 seconds
Time Taken: 0.00553 seconds
Time Before: 0.02385 seconds
Time After: 0.02424 seconds
Time Before: 0.02452 seconds
Time After: 0.02465 seconds
Time Before: 0.02543 seconds
Time After: 0.02758 seconds
Time Taken: 0.00215 seconds
Time Before: 0.02471 seconds
Time After: 0.03149 seconds
Time Taken: 0.00678 seconds
Time Before: 0.03800 seconds
Time After: 0.03820 seconds
Time Before: 0.04057 seconds
Time After: 0.04175 seconds
Time Taken: 0.00118 seconds
Time Before: 0.03736 seconds
Time After: 0.04195 seconds
Time Taken: 0.00459 seconds
Time Before: 0.07294 seconds
Time After: 0.07307 seconds
Time Before: 0.08600 seconds
Time After: 0.08882 seconds
Time Taken: 0.00282 seconds
Time Before: 0.09704 seconds
Time After: 0.09720 seconds
Time Before: 0.09959 seconds
Time After: 0.10103 seconds
UPDATE session SET lastactivity = 1783233884, location = '/forums/private.php?do=newpm&explain=1&u=116783', badlocation = 1 WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.11887 seconds
Time After: 0.11923 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
