Time Before: 0.01412 seconds
Time After: 0.01824 seconds
Time Taken: 0.00412 seconds
Time Before: 0.01836 seconds
Time After: 0.01884 seconds
Time Before: 0.01916 seconds
Time After: 0.01935 seconds
Time Before: 0.02027 seconds
Time After: 0.02310 seconds
Time Taken: 0.00283 seconds
Time Before: 0.01943 seconds
Time After: 0.02694 seconds
Time Taken: 0.00751 seconds
Time Before: 0.03168 seconds
Time After: 0.03209 seconds
Time Before: 0.03438 seconds
Time After: 0.03562 seconds
Time Before: 0.03110 seconds
Time After: 0.03586 seconds
Time Taken: 0.00476 seconds
Time Before: 0.06163 seconds
Time After: 0.06180 seconds
Time Before: 0.07172 seconds
Time After: 0.07295 seconds
Time Before: 0.08269 seconds
Time After: 0.08287 seconds
Time Before: 0.08551 seconds
Time After: 0.08699 seconds
UPDATE session SET lastactivity = 1776626762, location = '/forums/private.php?do=newpm&explain=1&u=116790' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.10479 seconds
Time After: 0.10516 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
