Time Before: 0.00146 seconds
Time After: 0.00193 seconds
Time Before: 0.00200 seconds
Time After: 0.00234 seconds
Time Before: 0.00251 seconds
Time After: 0.00263 seconds
Time Before: 0.00334 seconds
Time After: 0.00577 seconds
Time Taken: 0.00243 seconds
Time Before: 0.00267 seconds
Time After: 0.01060 seconds
Time Taken: 0.00793 seconds
Time Before: 0.01237 seconds
Time After: 0.01254 seconds
Time Before: 0.01529 seconds
Time After: 0.01646 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01180 seconds
Time After: 0.01671 seconds
Time Taken: 0.00490 seconds
Time Before: 0.02219 seconds
Time After: 0.02233 seconds
Time Before: 1.63592 seconds
Time After: 1.63747 seconds
Time Taken: 0.00156 seconds
Time Before: 1.64177 seconds
Time After: 1.64193 seconds
Time Before: 1.64531 seconds
Time After: 1.64681 seconds
UPDATE session SET lastactivity = 1789121766, location = '/forums/private.php?do=newpm&explain=1&u=116803', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 1.66104 seconds
Time After: 1.66138 seconds
