Time Before: 0.02049 seconds
Time After: 0.02438 seconds
Time Taken: 0.00389 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02448 seconds
Time After: 0.02504 seconds
Time Taken: 0.00056 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02528 seconds
Time After: 0.02541 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02626 seconds
Time After: 0.02880 seconds
Time Taken: 0.00254 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02549 seconds
Time After: 0.03291 seconds
Time Taken: 0.00742 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04025 seconds
Time After: 0.04045 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04344 seconds
Time After: 0.04492 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.03948 seconds
Time After: 0.04517 seconds
Time Taken: 0.00569 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.08369 seconds
Time After: 0.08382 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.15722 seconds
Time After: 0.15847 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.16139221191406
Time Before: 0.18809 seconds
Time After: 0.18827 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.19514 seconds
Time After: 0.19671 seconds
Time Taken: 0.00157 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1769303032, location = '/forums/private.php?do=newpm&explain=1&u=116824', badlocation = 1
WHERE sessionhash = '84a1ba763b341c65c6e779f4d27b10fd'
Time Before: 0.22279 seconds
Time After: 0.22308 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
Page generated in 0.22155904769897 seconds with 9 queries, spending 0.0083136558532715 doing MySQL queries and 0.2132453918457 doing PHP things.
