Time Before: 0.00144 seconds
Time After: 0.00205 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00212 seconds
Time After: 0.00273 seconds
Time Before: 0.00299 seconds
Time After: 0.00310 seconds
Time Before: 0.00376 seconds
Time After: 0.00613 seconds
Time Taken: 0.00237 seconds
Time Before: 0.00315 seconds
Time After: 0.00955 seconds
Time Taken: 0.00640 seconds
Time Before: 0.01153 seconds
Time After: 0.01200 seconds
Time Before: 0.01445 seconds
Time After: 0.01562 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01088 seconds
Time After: 0.01580 seconds
Time Taken: 0.00492 seconds
Time Before: 0.02112 seconds
Time After: 0.02127 seconds
Time Before: 0.02348 seconds
Time After: 0.02472 seconds
End call of global.php: 0.026459932327271
Time Before: 0.02763 seconds
Time After: 0.02779 seconds
Time Before: 0.02975 seconds
Time After: 0.03118 seconds
SET lastactivity = 1788952031, location = '/forums/private.php?do=newpm&explain=1&u=116828'
Time Before: 0.04343 seconds
Time After: 0.04407 seconds
Time Taken: 0.00064 seconds
Page generated in 0.042537927627563 seconds with 9 queries, spending 0.0083491802215576 doing MySQL queries and 0.034188747406006 doing PHP things.
