Time Before: 0.00144 seconds
Time After: 0.00186 seconds
Time Before: 0.00192 seconds
Time After: 0.00235 seconds
Time Before: 0.00260 seconds
Time After: 0.00273 seconds
Time Before: 0.00365 seconds
Time After: 0.00623 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00280 seconds
Time After: 0.00960 seconds
Time Taken: 0.00679 seconds
Time Before: 0.01141 seconds
Time After: 0.01188 seconds
Time Before: 0.01335 seconds
Time After: 0.01453 seconds
Time Before: 0.01080 seconds
Time After: 0.01470 seconds
Time Taken: 0.00390 seconds
Time Before: 0.01985 seconds
Time After: 0.01998 seconds
Time Before: 0.02237 seconds
Time After: 0.02360 seconds
End call of global.php: 0.025177001953125
Time Before: 0.02674 seconds
Time After: 0.02708 seconds
Time Before: 0.02912 seconds
Time After: 0.03137 seconds
Time Taken: 0.00226 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=116838', badlocation = 1
Time Before: 0.04755 seconds
Time After: 0.04798 seconds
Page generated in 0.046592235565186 seconds with 9 queries, spending 0.0091524124145508 doing MySQL queries and 0.037439823150635 doing PHP things.
