Time Before: 0.00458 seconds
Time After: 0.00595 seconds
Time Taken: 0.00136 seconds
Time Before: 0.00603 seconds
Time After: 0.00655 seconds
Time Before: 0.00677 seconds
Time After: 0.00693 seconds
Time Before: 0.00760 seconds
Time After: 0.01058 seconds
Time Taken: 0.00298 seconds
Time Before: 0.00698 seconds
Time After: 0.01393 seconds
Time Taken: 0.00694 seconds
Time Before: 0.01667 seconds
Time After: 0.01714 seconds
Time Before: 0.01956 seconds
Time After: 0.02082 seconds
Time Before: 0.01605 seconds
Time After: 0.02102 seconds
Time Taken: 0.00498 seconds
Time Before: 0.03191 seconds
Time After: 0.03207 seconds
Time Before: 0.03574 seconds
Time After: 0.03704 seconds
Time Before: 0.04099 seconds
Time After: 0.04118 seconds
Time Before: 0.04318 seconds
Time After: 0.04464 seconds
UPDATE session SET lastactivity = 1785417175, location = '/forums/private.php?do=newpm&explain=1&u=116855', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.05713 seconds
Time After: 0.05741 seconds
