Time Before: 0.00163 seconds
Time After: 0.00219 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00226 seconds
Time After: 0.00273 seconds
Time Before: 0.00297 seconds
Time After: 0.00310 seconds
Time Before: 0.00376 seconds
Time After: 0.00570 seconds
Time Taken: 0.00193 seconds
Time Before: 0.00315 seconds
Time After: 0.01073 seconds
Time Taken: 0.00759 seconds
Time Before: 0.01296 seconds
Time After: 0.01340 seconds
Time Before: 0.01589 seconds
Time After: 0.01708 seconds
Time Before: 0.01221 seconds
Time After: 0.01725 seconds
Time Taken: 0.00505 seconds
Time Before: 0.02269 seconds
Time After: 0.02284 seconds
Time Before: 0.02463 seconds
Time After: 0.02594 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.028517007827759
Time Before: 0.02981 seconds
Time After: 0.02998 seconds
Time Before: 0.03227 seconds
Time After: 0.03377 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=116866', badlocation = 1
Time Before: 0.04666 seconds
Time After: 0.04695 seconds
Page generated in 0.045732975006104 seconds with 9 queries, spending 0.0075790882110596 doing MySQL queries and 0.038153886795044 doing PHP things.
