Time Before: 0.00213 seconds
Time After: 0.00267 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00273 seconds
Time After: 0.00330 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00363 seconds
Time After: 0.00379 seconds
Time Before: 0.00469 seconds
Time After: 0.00763 seconds
Time Taken: 0.00294 seconds
Time Before: 0.00387 seconds
Time After: 0.01255 seconds
Time Taken: 0.00868 seconds
Time Before: 0.01479 seconds
Time After: 0.01521 seconds
Time Before: 0.01779 seconds
Time After: 0.01909 seconds
Time Before: 0.01394 seconds
Time After: 0.01940 seconds
Time Taken: 0.00546 seconds
Time Before: 0.02551 seconds
Time After: 0.02584 seconds
Time Before: 0.02804 seconds
Time After: 0.02934 seconds
End call of global.php: 0.030997037887573
Time Before: 0.03241 seconds
Time After: 0.03259 seconds
Time Before: 0.03504 seconds
Time After: 0.03656 seconds
Time Taken: 0.00152 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=116986', badlocation = 1
Time Before: 0.04938 seconds
Time After: 0.04966 seconds
Page generated in 0.048473119735718 seconds with 9 queries, spending 0.0089876651763916 doing MySQL queries and 0.039485454559326 doing PHP things.
