Time Before: 0.02053 seconds
Time After: 0.02614 seconds
Time Taken: 0.00560 seconds
Time Before: 0.02622 seconds
Time After: 0.02796 seconds
Time Taken: 0.00174 seconds
Time Before: 0.02825 seconds
Time After: 0.02838 seconds
Time Before: 0.02920 seconds
Time After: 0.03241 seconds
Time Taken: 0.00321 seconds
Time Before: 0.02845 seconds
Time After: 0.03655 seconds
Time Taken: 0.00810 seconds
Time Before: 0.04406 seconds
Time After: 0.04452 seconds
Time Before: 0.04800 seconds
Time After: 0.04921 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04324 seconds
Time After: 0.04943 seconds
Time Taken: 0.00620 seconds
Memory After: 2,261.703 KB
Time Before: 0.08687 seconds
Time After: 0.08701 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.10341 seconds
Time After: 0.10486 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.11438 seconds
Time After: 0.11456 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.11746 seconds
Time After: 0.11891 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=116987', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.13777 seconds
Time After: 0.13805 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
