Time Before: 0.02240 seconds
Time After: 0.02785 seconds
Time Taken: 0.00545 seconds
Time Before: 0.02797 seconds
Time After: 0.02885 seconds
Time Taken: 0.00089 seconds
Time Before: 0.02913 seconds
Time After: 0.02924 seconds
Time Before: 0.03008 seconds
Time After: 0.03245 seconds
Time Taken: 0.00238 seconds
Time Before: 0.02931 seconds
Time After: 0.03651 seconds
Time Taken: 0.00720 seconds
Time Before: 0.04976 seconds
Time After: 0.04999 seconds
Time Before: 0.05257 seconds
Time After: 0.05375 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04907 seconds
Time After: 0.05395 seconds
Time Taken: 0.00487 seconds
Time Before: 0.07938 seconds
Time After: 0.07953 seconds
Time Before: 1.99431 seconds
Time After: 1.99588 seconds
Time Taken: 0.00157 seconds
Time Before: 2.00724 seconds
Time After: 2.00742 seconds
Time Before: 2.01033 seconds
Time After: 2.01184 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=117000' WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 2.03193 seconds
Time After: 2.03219 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
