Time Before: 0.00150 seconds
Time After: 0.00200 seconds
Time Before: 0.00208 seconds
Time After: 0.00251 seconds
Time Before: 0.00273 seconds
Time After: 0.00288 seconds
Time Before: 0.00361 seconds
Time After: 0.00606 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00293 seconds
Time After: 0.00976 seconds
Time Taken: 0.00684 seconds
Time Before: 0.01177 seconds
Time After: 0.01201 seconds
Time Before: 0.01465 seconds
Time After: 0.01594 seconds
Time Before: 0.01105 seconds
Time After: 0.01618 seconds
Time Taken: 0.00513 seconds
Time Before: 0.02279 seconds
Time After: 0.02299 seconds
Time Before: 0.02549 seconds
Time After: 0.02680 seconds
Time Taken: 0.00131 seconds
Time Before: 0.03093 seconds
Time After: 0.03113 seconds
Time Before: 0.03414 seconds
Time After: 0.03569 seconds
Time Taken: 0.00155 seconds
UPDATE session SET lastactivity = 1783128920, location = '/forums/private.php?do=newpm&explain=1&u=117012', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.05013 seconds
Time After: 0.05045 seconds
