Time Before: 0.00148 seconds
Time After: 0.00205 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00215 seconds
Time After: 0.00265 seconds
Time Before: 0.00289 seconds
Time After: 0.00304 seconds
Time Before: 0.00385 seconds
Time After: 0.00663 seconds
Time Taken: 0.00278 seconds
Time Before: 0.00311 seconds
Time After: 0.01016 seconds
Time Taken: 0.00704 seconds
Time Before: 0.01208 seconds
Time After: 0.01247 seconds
Time Before: 0.01487 seconds
Time After: 0.01620 seconds
Time Taken: 0.00133 seconds
Time Before: 0.01145 seconds
Time After: 0.01644 seconds
Time Taken: 0.00500 seconds
Time Before: 0.02172 seconds
Time After: 0.02187 seconds
Time Before: 0.02373 seconds
Time After: 0.02497 seconds
End call of global.php: 0.026628017425537
Time Before: 0.02802 seconds
Time After: 0.02818 seconds
Time Before: 0.03050 seconds
Time After: 0.03201 seconds
Time Taken: 0.00152 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=117018', badlocation = 1
Time Before: 0.04800 seconds
Time After: 0.04824 seconds
Page generated in 0.046835899353027 seconds with 9 queries, spending 0.0084455013275146 doing MySQL queries and 0.038390398025513 doing PHP things.
