Time Before: 0.00422 seconds
Time After: 0.00676 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00685 seconds
Time After: 0.00732 seconds
Time Before: 0.00757 seconds
Time After: 0.00771 seconds
Time Before: 0.00847 seconds
Time After: 0.01111 seconds
Time Taken: 0.00264 seconds
Time Before: 0.00779 seconds
Time After: 0.01549 seconds
Time Taken: 0.00770 seconds
Time Before: 0.01960 seconds
Time After: 0.01999 seconds
Time Before: 0.02253 seconds
Time After: 0.02371 seconds
Time Before: 0.01890 seconds
Time After: 0.02395 seconds
Time Taken: 0.00504 seconds
Time Before: 0.03693 seconds
Time After: 0.03713 seconds
Time Before: 0.04314 seconds
Time After: 0.04465 seconds
Time Taken: 0.00151 seconds
End call of global.php: 0.046355009078979
Time Before: 0.04976 seconds
Time After: 0.04989 seconds
Time Before: 0.05199 seconds
Time After: 0.05345 seconds
SET lastactivity = 1789113962, location = '/forums/private.php?do=newpm&explain=1&u=117031', badlocation = 1
Time Before: 0.07227 seconds
Time After: 0.07257 seconds
Page generated in 0.070827007293701 seconds with 9 queries, spending 0.0084559917449951 doing MySQL queries and 0.062371015548706 doing PHP things.
