Time Before: 0.00341 seconds
Time After: 0.00450 seconds
Time Taken: 0.00109 seconds
Time Before: 0.00460 seconds
Time After: 0.00496 seconds
Time Before: 0.00525 seconds
Time After: 0.00547 seconds
Time Before: 0.00630 seconds
Time After: 0.00878 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00555 seconds
Time After: 0.01397 seconds
Time Taken: 0.00842 seconds
Time Before: 0.01686 seconds
Time After: 0.01723 seconds
Time Before: 0.02021 seconds
Time After: 0.02145 seconds
Time Before: 0.01590 seconds
Time After: 0.02179 seconds
Time Taken: 0.00589 seconds
Time Before: 0.03358 seconds
Time After: 0.03376 seconds
Time Before: 0.03736 seconds
Time After: 0.03862 seconds
Time Before: 0.04396 seconds
Time After: 0.04414 seconds
Time Before: 0.04742 seconds
Time After: 0.04975 seconds
Time Taken: 0.00233 seconds
UPDATE session SET lastactivity = 1776517524, location = '/forums/private.php?do=newpm&explain=1&u=117066', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.06513 seconds
Time After: 0.06544 seconds
