Time Before: 0.00174 seconds
Time After: 0.00236 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00243 seconds
Time After: 0.00323 seconds
Time Taken: 0.00080 seconds
Time Before: 0.00352 seconds
Time After: 0.00380 seconds
Time Before: 0.00474 seconds
Time After: 0.00765 seconds
Time Taken: 0.00291 seconds
Time Before: 0.00388 seconds
Time After: 0.01292 seconds
Time Taken: 0.00905 seconds
Time Before: 0.01605 seconds
Time After: 0.01646 seconds
Time Before: 0.01942 seconds
Time After: 0.02072 seconds
Time Before: 0.01516 seconds
Time After: 0.02093 seconds
Time Taken: 0.00577 seconds
Time Before: 0.02631 seconds
Time After: 0.02643 seconds
Time Before: 0.02837 seconds
Time After: 0.02963 seconds
Time Before: 0.03264 seconds
Time After: 0.03278 seconds
Time Before: 0.03473 seconds
Time After: 0.03628 seconds
Time Taken: 0.00155 seconds
UPDATE session SET lastactivity = 1776554244, location = '/forums/private.php?do=newpm&explain=1&u=117077', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.04876 seconds
Time After: 0.04901 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
