Time Before: 0.00666 seconds
Time After: 0.00971 seconds
Time Taken: 0.00304 seconds
Time Before: 0.00978 seconds
Time After: 0.01023 seconds
Time Before: 0.01044 seconds
Time After: 0.01056 seconds
Time Before: 0.01138 seconds
Time After: 0.01411 seconds
Time Taken: 0.00273 seconds
Time Before: 0.01064 seconds
Time After: 0.01801 seconds
Time Taken: 0.00737 seconds
Time Before: 0.02226 seconds
Time After: 0.02268 seconds
Time Before: 0.02598 seconds
Time After: 0.02738 seconds
Time Taken: 0.00140 seconds
Time Before: 0.02159 seconds
Time After: 0.02764 seconds
Time Taken: 0.00605 seconds
Time Before: 0.04863 seconds
Time After: 0.04879 seconds
Time Before: 0.05673 seconds
Time After: 0.05794 seconds
End call of global.php: 0.060135126113892
Time Before: 0.06322 seconds
Time After: 0.06337 seconds
Time Before: 0.06583 seconds
Time After: 0.06723 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=117097', badlocation = 1
Time Before: 0.08377 seconds
Time After: 0.08407 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.08270001411438 seconds with 9 queries, spending 0.0083560943603516 doing MySQL queries and 0.074343919754028 doing PHP things.
