Time Before: 0.00872 seconds
Time After: 0.01402 seconds
Time Taken: 0.00530 seconds
Time Before: 0.01413 seconds
Time After: 0.01453 seconds
Time Before: 0.01488 seconds
Time After: 0.01505 seconds
Time Before: 0.01597 seconds
Time After: 0.01859 seconds
Time Taken: 0.00262 seconds
Time Before: 0.01512 seconds
Time After: 0.02274 seconds
Time Taken: 0.00761 seconds
Time Before: 0.03100 seconds
Time After: 0.03143 seconds
Time Before: 0.03423 seconds
Time After: 0.03540 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03029 seconds
Time After: 0.03559 seconds
Memory After: 2,261.703 KB
Time Before: 0.05362 seconds
Time After: 0.05430 seconds
Time Taken: 0.00068 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 2.37936 seconds
Time After: 2.38079 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 2.39296 seconds
Time After: 2.39315 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 2.39537 seconds
Time After: 2.39681 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=117116' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 2.41594 seconds
Time After: 2.41621 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
