Time Before: 0.00137 seconds
Time After: 0.00184 seconds
Time Before: 0.00191 seconds
Time After: 0.00239 seconds
Time Before: 0.00258 seconds
Time After: 0.00268 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00340 seconds
Time After: 0.00592 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00272 seconds
Time After: 0.01030 seconds
Time Taken: 0.00757 seconds
Time Before: 0.01274 seconds
Time After: 0.01311 seconds
Time Before: 0.01582 seconds
Time After: 0.01706 seconds
Time Before: 0.01199 seconds
Time After: 0.01732 seconds
Time Taken: 0.00534 seconds
Time Before: 0.02314 seconds
Time After: 0.02330 seconds
Time Before: 0.02568 seconds
Time After: 0.02690 seconds
End call of global.php: 0.028806924819946
Time Before: 0.03038 seconds
Time After: 0.03057 seconds
Time Before: 0.03286 seconds
Time After: 0.03429 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=117154'
Time Before: 0.04665 seconds
Time After: 0.04692 seconds
Page generated in 0.045753955841064 seconds with 9 queries, spending 0.0079700946807861 doing MySQL queries and 0.037783861160278 doing PHP things.
