Time Before: 0.00145 seconds
Time After: 0.00198 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00205 seconds
Time After: 0.00258 seconds
Time Before: 0.00283 seconds
Time After: 0.00296 seconds
Time Before: 0.00371 seconds
Time After: 0.00615 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00301 seconds
Time After: 0.00964 seconds
Time Taken: 0.00664 seconds
Time Before: 0.01150 seconds
Time After: 0.01192 seconds
Time Before: 0.01347 seconds
Time After: 0.01468 seconds
Time Before: 0.01085 seconds
Time After: 0.01485 seconds
Time Taken: 0.00399 seconds
Time Before: 0.01989 seconds
Time After: 0.02004 seconds
Time Before: 0.02212 seconds
Time After: 0.02356 seconds
Time Before: 0.02774 seconds
Time After: 0.02789 seconds
Time Before: 0.03057 seconds
Time After: 0.03212 seconds
Time Taken: 0.00156 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=117187', badlocation = 1 WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.04537 seconds
Time After: 0.04564 seconds
