Time Before: 0.01508 seconds
Time After: 0.02146 seconds
Time Taken: 0.00637 seconds
Time Before: 0.02156 seconds
Time After: 0.02207 seconds
Time Before: 0.02240 seconds
Time After: 0.02255 seconds
Time Before: 0.02339 seconds
Time After: 0.02577 seconds
Time Taken: 0.00237 seconds
Time Before: 0.02262 seconds
Time After: 0.03022 seconds
Time Taken: 0.00760 seconds
Time Before: 0.03811 seconds
Time After: 0.03858 seconds
Time Before: 0.04127 seconds
Time After: 0.04250 seconds
Time Before: 0.03740 seconds
Time After: 0.04275 seconds
Time Taken: 0.00535 seconds
Time Before: 0.07829 seconds
Time After: 0.07843 seconds
Time Before: 0.09456 seconds
Time After: 0.09580 seconds
End call of global.php: 0.097751140594482
Time Before: 0.10573 seconds
Time After: 0.10593 seconds
Time Before: 0.10921 seconds
Time After: 0.11069 seconds
SET lastactivity = 1783211924, location = '/forums/private.php?do=newpm&explain=1&u=117191'
Time Before: 0.12902 seconds
Time After: 0.12947 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.1278669834137 seconds with 9 queries, spending 0.0082430839538574 doing MySQL queries and 0.11962389945984 doing PHP things.
