Time Before: 0.00642 seconds
Time After: 0.00782 seconds
Time Taken: 0.00139 seconds
Time Before: 0.00791 seconds
Time After: 0.00831 seconds
Time Before: 0.00858 seconds
Time After: 0.00870 seconds
Time Before: 0.00951 seconds
Time After: 0.01172 seconds
Time Taken: 0.00221 seconds
Time Before: 0.00876 seconds
Time After: 0.01598 seconds
Time Taken: 0.00722 seconds
Time Before: 0.02003 seconds
Time After: 0.02040 seconds
Time Before: 0.02280 seconds
Time After: 0.02398 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01930 seconds
Time After: 0.02419 seconds
Time Taken: 0.00488 seconds
Time Before: 0.03894 seconds
Time After: 0.03911 seconds
Time Before: 0.04404 seconds
Time After: 0.04542 seconds
Time Taken: 0.00138 seconds
Time Before: 0.04989 seconds
Time After: 0.05008 seconds
Time Before: 0.05309 seconds
Time After: 0.05460 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=117208', badlocation = 1 WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.07155 seconds
Time After: 0.07179 seconds
