Time Before: 0.00231 seconds
Time After: 0.00307 seconds
Time Taken: 0.00076 seconds
Time Before: 0.00314 seconds
Time After: 0.00361 seconds
Time Before: 0.00388 seconds
Time After: 0.00405 seconds
Time Before: 0.00493 seconds
Time After: 0.00741 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00412 seconds
Time After: 0.01171 seconds
Time Taken: 0.00759 seconds
Time Before: 0.01363 seconds
Time After: 0.01409 seconds
Time Before: 0.01665 seconds
Time After: 0.01789 seconds
Time Before: 0.01297 seconds
Time After: 0.01813 seconds
Time Taken: 0.00516 seconds
Time Before: 0.02372 seconds
Time After: 0.02389 seconds
Time Before: 0.02604 seconds
Time After: 0.02730 seconds
End call of global.php: 0.029635906219482
Time Before: 0.03102 seconds
Time After: 0.03118 seconds
Time Before: 0.03387 seconds
Time After: 0.03532 seconds
SET lastactivity = 1788972527, location = '/forums/private.php?do=newpm&explain=1&u=117219'
Time Before: 0.05371 seconds
Time After: 0.05405 seconds
Page generated in 0.052669048309326 seconds with 9 queries, spending 0.008195161819458 doing MySQL queries and 0.044473886489868 doing PHP things.
