Time Before: 0.02179 seconds
Time After: 0.02564 seconds
Time Taken: 0.00385 seconds
Time Before: 0.02576 seconds
Time After: 0.02623 seconds
Time Before: 0.02652 seconds
Time After: 0.02664 seconds
Time Before: 0.02758 seconds
Time After: 0.03028 seconds
Time Taken: 0.00271 seconds
Time Before: 0.02671 seconds
Time After: 0.03432 seconds
Time Taken: 0.00761 seconds
Time Before: 0.04093 seconds
Time After: 0.04111 seconds
Time Before: 0.04350 seconds
Time After: 0.04485 seconds
Time Taken: 0.00135 seconds
Time Before: 0.04026 seconds
Time After: 0.04512 seconds
Time Taken: 0.00486 seconds
Time Before: 0.07626 seconds
Time After: 0.07643 seconds
Time Before: 0.09759 seconds
Time After: 0.09886 seconds
Time Before: 0.10700 seconds
Time After: 0.10719 seconds
Time Before: 0.10968 seconds
Time After: 0.11128 seconds
Time Taken: 0.00161 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=117223', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.13116 seconds
Time After: 0.13146 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
