Time Before: 0.01378 seconds
Time After: 0.01877 seconds
Time Taken: 0.00500 seconds
Time Before: 0.01891 seconds
Time After: 0.01932 seconds
Time Before: 0.01959 seconds
Time After: 0.01971 seconds
Time Before: 0.02051 seconds
Time After: 0.02263 seconds
Time Taken: 0.00212 seconds
Time Before: 0.01978 seconds
Time After: 0.02664 seconds
Time Taken: 0.00687 seconds
Time Before: 0.03350 seconds
Time After: 0.03396 seconds
Time Before: 0.03644 seconds
Time After: 0.03770 seconds
Time Before: 0.03287 seconds
Time After: 0.03788 seconds
Time Taken: 0.00501 seconds
Time Before: 0.06019 seconds
Time After: 0.06037 seconds
Time Before: 0.07500 seconds
Time After: 0.07626 seconds
Time Before: 0.08401 seconds
Time After: 0.08419 seconds
Time Before: 0.08658 seconds
Time After: 0.08804 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=117256', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.10817 seconds
Time After: 0.10847 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
