Time Before: 0.00147 seconds
Time After: 0.00205 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00212 seconds
Time After: 0.00247 seconds
Time Before: 0.00265 seconds
Time After: 0.00279 seconds
Time Before: 0.00361 seconds
Time After: 0.00607 seconds
Time Taken: 0.00246 seconds
Time Before: 0.00284 seconds
Time After: 0.00977 seconds
Time Taken: 0.00692 seconds
Time Before: 0.01175 seconds
Time After: 0.01204 seconds
Time Before: 0.01472 seconds
Time After: 0.01599 seconds
Time Before: 0.01100 seconds
Time After: 0.01620 seconds
Time Taken: 0.00520 seconds
Time Before: 0.02142 seconds
Time After: 0.02154 seconds
Time Before: 0.02373 seconds
Time After: 0.02509 seconds
Time Taken: 0.00136 seconds
End call of global.php: 0.026763916015625
Time Before: 0.02792 seconds
Time After: 0.02807 seconds
Time Before: 0.03008 seconds
Time After: 0.03151 seconds
SET lastactivity = 1773314368, location = '/forums/private.php?do=newpm&explain=1&u=11728', badlocation = 1
Time Before: 0.04554 seconds
Time After: 0.04586 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.044615983963013 seconds with 9 queries, spending 0.0078804492950439 doing MySQL queries and 0.036735534667969 doing PHP things.
