Time Before: 0.00134 seconds
Time After: 0.00185 seconds
Time Before: 0.00192 seconds
Time After: 0.00311 seconds
Time Before: 0.00375 seconds
Time After: 0.00426 seconds
Time Before: 0.00507 seconds
Time After: 0.00798 seconds
Time Taken: 0.00291 seconds
Time Before: 0.00431 seconds
Time After: 0.01136 seconds
Time Taken: 0.00705 seconds
Time Before: 0.01353 seconds
Time After: 0.01400 seconds
Time Before: 0.01685 seconds
Time After: 0.01804 seconds
Time Before: 0.01277 seconds
Time After: 0.01832 seconds
Time Taken: 0.00555 seconds
Time Before: 0.02473 seconds
Time After: 0.02488 seconds
Time Before: 0.02696 seconds
Time After: 0.02825 seconds
Time Before: 0.03338 seconds
Time After: 0.03384 seconds
Time Before: 0.03749 seconds
Time After: 0.03901 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1789137443, location = '/forums/private.php?do=newpm&explain=1&u=117303' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.05239 seconds
Time After: 0.05269 seconds
