Time Before: 0.01506 seconds
Time After: 0.01854 seconds
Time Taken: 0.00348 seconds
Time Before: 0.01863 seconds
Time After: 0.01902 seconds
Time Before: 0.01928 seconds
Time After: 0.01941 seconds
Time Before: 0.02026 seconds
Time After: 0.02242 seconds
Time Taken: 0.00216 seconds
Time Before: 0.01949 seconds
Time After: 0.02767 seconds
Time Taken: 0.00818 seconds
Time Before: 0.03324 seconds
Time After: 0.03368 seconds
Time Before: 0.03660 seconds
Time After: 0.03792 seconds
Time Taken: 0.00131 seconds
Time Before: 0.03250 seconds
Time After: 0.03816 seconds
Time Taken: 0.00566 seconds
Time Before: 0.06409 seconds
Time After: 0.06421 seconds
Time Before: 0.07564 seconds
Time After: 0.07684 seconds
Time Before: 0.08213 seconds
Time After: 0.08235 seconds
Time Before: 0.08481 seconds
Time After: 0.08622 seconds
UPDATE session SET lastactivity = 1785404409, location = '/forums/private.php?do=newpm&explain=1&u=117321', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.10212 seconds
Time After: 0.10252 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
