Time Before: 0.00171 seconds
Time After: 0.00229 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00236 seconds
Time After: 0.00289 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00316 seconds
Time After: 0.00333 seconds
Time Before: 0.00422 seconds
Time After: 0.00656 seconds
Time Taken: 0.00234 seconds
Time Before: 0.00341 seconds
Time After: 0.01195 seconds
Time Taken: 0.00854 seconds
Time Before: 0.01454 seconds
Time After: 0.01495 seconds
Time Before: 0.01736 seconds
Time After: 0.01852 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01374 seconds
Time After: 0.01876 seconds
Time Taken: 0.00502 seconds
Time Before: 0.02598 seconds
Time After: 0.02615 seconds
Time Before: 0.02879 seconds
Time After: 0.03004 seconds
End call of global.php: 0.032780885696411
Time Before: 0.03428 seconds
Time After: 0.03442 seconds
Time Before: 0.03740 seconds
Time After: 0.03881 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=117331', badlocation = 1
WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.05229 seconds
Time After: 0.05289 seconds
Time Taken: 0.00059 seconds
Page generated in 0.051359891891479 seconds with 9 queries, spending 0.0081827640533447 doing MySQL queries and 0.043177127838135 doing PHP things.
