Time Before: 0.00140 seconds
Time After: 0.00193 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00200 seconds
Time After: 0.00236 seconds
Time Before: 0.00257 seconds
Time After: 0.00270 seconds
Time Before: 0.00340 seconds
Time After: 0.00555 seconds
Time Taken: 0.00215 seconds
Time Before: 0.00275 seconds
Time After: 0.00905 seconds
Time Taken: 0.00631 seconds
Time Before: 0.01104 seconds
Time After: 0.01146 seconds
Time Before: 0.01463 seconds
Time After: 0.01586 seconds
Time Before: 0.01030 seconds
Time After: 0.01607 seconds
Time Taken: 0.00577 seconds
Time Before: 0.02432 seconds
Time After: 0.02468 seconds
Time Before: 0.02768 seconds
Time After: 0.02917 seconds
End call of global.php: 0.031893968582153
Time Before: 0.03354 seconds
Time After: 0.03379 seconds
Time Before: 0.03700 seconds
Time After: 0.03849 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=117335', badlocation = 1
Time Before: 0.05389 seconds
Time After: 0.05415 seconds
Page generated in 0.052958965301514 seconds with 9 queries, spending 0.008134126663208 doing MySQL queries and 0.044824838638306 doing PHP things.
