Time Before: 0.00794 seconds
Time After: 0.01112 seconds
Time Taken: 0.00319 seconds
Time Before: 0.01122 seconds
Time After: 0.01165 seconds
Time Before: 0.01192 seconds
Time After: 0.01209 seconds
Time Before: 0.01293 seconds
Time After: 0.01529 seconds
Time Taken: 0.00237 seconds
Time Before: 0.01219 seconds
Time After: 0.01948 seconds
Time Taken: 0.00730 seconds
Time Before: 0.02486 seconds
Time After: 0.02529 seconds
Time Before: 0.02783 seconds
Time After: 0.02907 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.02415 seconds
Time After: 0.02929 seconds
Time Taken: 0.00514 seconds
Memory After: 2,261.719 KB
Time Before: 0.04286 seconds
Time After: 0.04301 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.05096 seconds
Time After: 0.05220 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.05820 seconds
Time After: 0.05837 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.06063 seconds
Time After: 0.06214 seconds
Time Taken: 0.00151 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=11734' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.07969 seconds
Time After: 0.07997 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
