Time Before: 0.00212 seconds
Time After: 0.00266 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00273 seconds
Time After: 0.00329 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00355 seconds
Time After: 0.00375 seconds
Time Before: 0.00450 seconds
Time After: 0.00736 seconds
Time Taken: 0.00286 seconds
Time Before: 0.00380 seconds
Time After: 0.01091 seconds
Time Taken: 0.00712 seconds
Time Before: 0.01323 seconds
Time After: 0.01359 seconds
Time Before: 0.01595 seconds
Time After: 0.01730 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01263 seconds
Time After: 0.01748 seconds
Time Taken: 0.00485 seconds
Memory After: 2,261.703 KB
Time Before: 0.02403 seconds
Time After: 0.02428 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02778 seconds
Time After: 0.02907 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.030728101730347
Time Before: 0.03212 seconds
Time After: 0.03231 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03426 seconds
Time After: 0.03571 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=117387', badlocation = 1
Time Before: 0.04828 seconds
Time After: 0.04854 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.047363996505737 seconds with 9 queries, spending 0.0087618827819824 doing MySQL queries and 0.038602113723755 doing PHP things.
