Time Before: 0.00148 seconds
Time After: 0.00191 seconds
Time Before: 0.00197 seconds
Time After: 0.00248 seconds
Time Before: 0.00273 seconds
Time After: 0.00289 seconds
Time Before: 0.00361 seconds
Time After: 0.00597 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00294 seconds
Time After: 0.00987 seconds
Time Taken: 0.00693 seconds
Time Before: 0.01151 seconds
Time After: 0.01192 seconds
Time Before: 0.01450 seconds
Time After: 0.01571 seconds
Time Before: 0.01092 seconds
Time After: 0.01588 seconds
Time Taken: 0.00496 seconds
Time Before: 0.02068 seconds
Time After: 0.02083 seconds
Time Before: 0.02252 seconds
Time After: 0.02373 seconds
End call of global.php: 0.025339841842651
Time Before: 0.02644 seconds
Time After: 0.02659 seconds
Time Before: 0.02853 seconds
Time After: 0.02999 seconds
SET lastactivity = 1785351454, location = '/forums/private.php?do=newpm&explain=1&u=117397'
Time Before: 0.04239 seconds
Time After: 0.04264 seconds
Page generated in 0.041473865509033 seconds with 9 queries, spending 0.0078589916229248 doing MySQL queries and 0.033614873886108 doing PHP things.
